Group: DynoMotion Message: 999 From: albertplatek Date: 3/25/2011
Subject: KMotionCNC zero axis bug
Hi Tom
I have found a bug in KMotionCNC, when you move axis in some position, zero them
and then type command G00 X0 Y0 Z0, it move not to zero position but to zero
Machine Coord (!) it happens always after first launch KMotionCNC
second try is ok.
Albert P³atek
Group: DynoMotion Message: 1000 From: Tom Kerekes Date: 3/25/2011
Subject: Re: KMotionCNC zero axis bug
Hi Albert,
The bug should be fixed in this executable.  Save it to the V4.23 Release directory.  Please let us know if it fixes the problem.
Thanks for the report.
Group: DynoMotion Message: 1001 From: albertplatek Date: 3/25/2011
New file from you solved the problem. Now KMotionCNC its not moving in wrong position after zero axis.
Thank you for fast response and fixing the problem.
Albert P³atek
> Hi Albert,
> http://www.dynomotion.com/Software/FixZeroBeforeExecute/KMotionCNC.exe
> From: albertplatek <albertplatek86@...>
> Sent: Fri, March 25, 2011 2:14:48 AM
> Subject: [DynoMotion] KMotionCNC zero axis bug
> Hi Tom
> second try is ok.
> Albert P³atek
